Question changing struts?
RuDawg
Red Cloud
I am swapping out my struts so I can use a sissy bar.
Are you able to release the pins at the plug connected to the rear lights so I can pull the wires through the hole in the old strut and route into the new one? I have been trying to release them with a small nail with no luck.
I really don't want to mess with it at the wiring harness. I am thinking if I can't get the pins loose, I will cut the wires and put a quick connect since I want to take these struts off later and send to the chromer.
I appreciate any help!
RU
Banned
I use a dental pick to remove those pins.. but have heard a safety pin will work.. just take your time.. I wouldnt cut the wires..
RuDawg
Red Cloud
Got'm! I was trying to realease them from the back side where the wires go in the plug, instead of from the bottom. Thanks again Eric!
