problem changing down
Gaz
Hi could someone give me some advice please, lm having difficultys with my 2006 K9 changing down, it will change from 6th to 5th gear no problem, and then but not all the time l cant find any gears, the only change l have made is having a baker 3 inch belt drive installed, could this some how have caused the problem?
Thank you in advance
Gaz
Welcome from Kansas. Sounds like you need to adjust your clutch....?
BadDawg Bill
As I said in another thread, if you can put a nickle in between the lever and the stop it's adjusted right. Just back off the nut on the adjuster until it fits. Squeeze a few times to make sure it's adjusted...
