Makes perfect sense to me.Overall an informative vid. However, I'm not trying to be some know-it-all, but rather walk my theory out. Here is where I disagree about catching N and/or clunk. The rest I agree with:
1. The engine turns the clutch outer in a continuous motion.
2. The engine moves in a power on-power off, where this would slack the chain no matter how loose/tight, then the other cylinder fires, etc.
3. The steel wave plate shows a slight wave into the clutch center, where a liquid/cable lever throw is not about to have a full throw.
4, The rod moves back into the slave cylinder/roller ramps and now cannot separate the plates far enough, via wave plate concaving.
5. The drag of a single plate keeps rotating the clutch center and that friction can cause hard disengagement/clunk/etc.
6. The chain has nothing to do with gear dis/engagements, but has everything to do with the wave plate running as flat as a pancake.
There is your trouble finding N... to stop the clutch center from rotating. That's my theory and I'm sticking to it.
Signed,
NOLTT (no one listens to turtle)
So explain why when we make this adjustment, provided all other variables are correctly set, it alleviates the issue of finding neutral and the "clunck"? Not being confrontational or trying to start anything just looking for the same type of intelligent answer like you gave previously.Overall an informative vid. However, I'm not trying to be some know-it-all, but rather walk my theory out. Here is where I disagree about catching N and/or clunk. The rest I agree with:
Signed,
Can't rotate the tire hardly at all by hand if plugs are in...compressionNot sure I understand the removal of plugs and rotating the tire, in essence nothing will change once adjusted properly at any given point.
Good point I thought this was a different thread about lifters...my bad. There's another thread recently on that..lol . Must be all the threads you been digging up from the grave! HahaI thought it was just a video on adjusting the chain
Old age is creepin up on ya,Good point I thought this was a different thread about lifters...my bad. There's another thread recently on that..lol . Must be all the threads you been digging up from the grave! Haha
I've had a hard time posting for a few weeks says I don't have privileges on my tapatalk so why y'all haven't heard from me and obviously why I'm confused on the thread I'm posting on. I'll go back in my hole. Haha
