PHATASS
Here are all the part numbers. You may be able to re-use your primary cover o-ring if it's not damaged. Check out the "VENDORS" section on the toolbar above and they should have everything listed below.
Inspection Cover Gasket BD120-000045-00 $3.99
Primary Cover O-Ring BD120-00005-00 $14.95
1 QT Revtech Translission Oil 35-055 $6.65
Main Shaft Left Side Seal BDBDM110-00207 $6.95
Clutch Hub Shim BD240-000313-00 $5.90
