pauldeepsea
changed the oil on the big bear about a week ago and while riding last week I had oil leaking from the rear pushrod in 2 places. At the bottom of the pushrod near the tappet and from the middle of the pushrod. Thought may have overfilled the oil tank.
Decided to drain oil out of the crankcase and try again. Sure enough more oil leaking.
orings are shot in the pushrod?
Also I used some high temp silicone around the air filter to stop oil from misting out of the breather tubes on the air filter, really wondering if the motor may not be breathing and causing the oil to leak? Really leaning towards the seals being worn! May have to remove the pushrods and check them out. I have never done a pushrod replacement. I think it's doable?
JK, I am already planning to do an overhaul soon and new lifters are gonna be part of that.
