Not sure if this is the correct place to post this, however need help. I have a 2006 BD K9 with only 2000 miles. A lot happen and my son and I installed a new Wire Plus. Took us all day, since we were very careful about splicing and putting it together correctly. Only mistake was that we did not have as solid a ground as we should have. So to remedy that we pulled all of the grounds together and came up with a solid ground. It curred some of the issues, except for the brake light that is on the front brake lever it does not light up the back brake light when pulled, the tach is eratic and the neutral switch stays on in all gears. We called Wire Plus and the tech was very nice and related it all to a bad ground (which I think we fixed). However we are still having trouble with the Brake light at the lever (which is hard to understand since I would assume that the foot and hand are connected together, even rewired that), the neutral light stays on all the time and the tach does not work. Now a new problem, it will not start, cranks good just will not start. We checked to see if we were getting fire to the plug and we are not, had the coil checked it was fine. Please someone help us with these issues:
Brake light will not come on when hand brake is applied
Neutral light stays on all the time.
Tach is eratic
Will not start (coil good and is getting gas, and yes it has gas).
If Wire Plus is on the forum or anyone else that can help it is greatly appreciated. My son in the Air Force wants to ride.
Thanks
Dick
Tach is eratic
Thanks
Dick
