No spark to plugs
Dnyomo
I have a 2004 Big Dog I put in a wire plus module now I have no spark to the plugs. It was running after I put the wire plus module but it would die can anyone help
erldawg
OK I have to ask.. I have no experience with WP install. However did you re check all your wires?
Dnyomo
Yes It seems to be wired correctly, I have power going to the coil but no spark to the plugs. The coil is a new coil, is there a way to check if the coil is bad?
DRBarnhart
Insert title here...
Yes It seems to be wired correctly...
I have to tell you it either IS or ISN'T wired correctly, there's no "seems to be" about it! :rant:
Do you have power to the ignition module? And if there is, do the other lights on the ignition module blink while it's turning it over? :confused:
Check continuity of the primary and secondary of the coil. What values do you get? :confused::confused:
If everything else checks OK I'd be checking the wiring and the cam sensor... :D
Dennis
Dnyomo
04 no spark to plugs
When I turn the bike over the green light on the ignition module comes on but then shuts off while the bike is turning over. I am looking at the directions that wire plus gave me and it does not look like the same module the one I have only has the one green light on it. Again I have power to the two leads on the coil but no spark to the plugs?
