05 old dog
ok top end rebuild...fire on front cylinder comes and goes...here most of the time...have retightened everything electrical...grounds ...positive...have opened connectors and checked wiggled them....no help...now the thunderheart blinks the red yellow blue all the time....last time front cylinder wasnt firing i used the volt meter and checked the yellow wire on the coil and it had 12 volts going to it but no spark to plug. i even touched volt meter to it and nothing....doest make since but, shut bike off...switched the spark plug wires...which i have DONE before and made no difference...thought what the hell...started bike and both firing and ran 5 min or so and brought heat up in cylinders to 180 degrees for warm up cycle....im thinking coil is bad...wanting to go to the thunderheart 5012 anyway...but ive heard that most arent using that coil...whats my options...did clean crank sensor...it had a little residue on it but no change. should also state that the bike has PDM ...which brings up another question...can this new wiring system be jumped with car battery or use a regular battery charger to trickle charge???
