You can be cheap and get the one I have for around 1400.:2thumbs:yeah cheaper fix but love the look of the open belt
:bang: :roll: :loony:I have the Primo Xtreme which is the cheaper out of the 2 Primo. It has a 1 piece backing plate. Alhall has the Primo Brute 4 I believe which is the more expensive one and it has a 2 piece backing plate which is adjustable. It's really simple to switch over. Al did a how to on his when he swapped out. It takes about an hour or so. The hardest part is getting the motor nut off. You need to have a good impact gun. The second is to get the race off which there is a tool or you can do what I did. I dremeled both sides and knocked it right out.rainman what kind of open primary do you have and was the install easy
Norainman did you have to extend the pegs and shifter peg when you went to open belt
Wicked Image is custom making linkages for the Big Dogs for $199.00 Takes around 3 weeks to get them in, but they've told me that they can do it for any of their styles.Gas, where did you get the Shifter Rod?
