need help
sgrind1
i have 03 pitbull i have a few leaks around primary first cover gasket now it looks like i have oil coming from the back side maybe starter area.
? if i go to internal belt drive or open belt drive would this eliminate all oil problems in this area?
V
It would make your setup a dry primary and you would need to make sure that the engine seal is reversed to prevent engine leaks.
But would be a lot cheaper to fix the gasket.:2thumbs:
V
BBChopper
Supports 2 Disabled Vets
Oh leave it be. Just hang an HD badge on it!:eek:
Fix da leak! A leaking dog is never good, in your house or not!:eek:
:roll: :roll: :2thumbs: :2thumbs:
surferdude
dry docked
Ok ... where do we get a HD badge? jk ... put some sillycone on it and it should stop leaking .... my inspection cover leaked no matter how tight I made it and the service guy said to put the sillycone on it and it stopped leaking ... but I torqued my inspection cover too much and now I'm ordering a new one ... :spank: :bang: :roll: :loony:
CCRainman
rainman what kind of open primary do you have and was the install easy
I have the Primo Xtreme which is the cheaper out of the 2 Primo. It has a 1 piece backing plate. Alhall has the Primo Brute 4 I believe which is the more expensive one and it has a 2 piece backing plate which is adjustable. It's really simple to switch over. Al did a how to on his when he swapped out. It takes about an hour or so. The hardest part is getting the motor nut off. You need to have a good impact gun. The second is to get the race off which there is a tool or you can do what I did. I dremeled both sides and knocked it right out.
My pipes are not good for the passenger. The exhaust exits right there and the wifey's feet get really hot.
