My turn I guess...... FUCK!!!!!!
Pu239
If the red Loctite was covering up the battery connection threads and maybe the wire-connector rings, you had an insulator - not a clean, tight electrical connection. Backing out the bolts/screws & cleaning probably helped you on your way. Ride safe.
JimNubs
As long as the loctite was only on the threads you would be alright. But with the loose connection from riding yesterday, the post might have overheated then. After the metal heated for the first time, the tinsel strength in the nut is gone. You will have continuous problems. Try and replace the nut inside the post and use a new screw.
Take the battery post off on the neg side. Touch it back on. It should not spike removing or replacing cable. If it arcs then direct short on the posi side of some component.
Coolbreezin
Yiiii-Haaaaa!!!! I can´t stress it enough.... "All Connections Clean & Tight!"
Negative Battery Pole was loose........ AND I had RED Loctite in them..... Always remember that these vibrations can loosen up ANYTHING & EVERYTHING!!!!!!
:whoop: :chopper::chopper::chopper::chopper:
I too did the red Locktite. I also had lock washer on it. Still came loose. Thinking about doing a wire tie to it.
francoblay1
The Spaniard
Ok.... I´ve been two hours fucking around trying to get rid of the hungover, I am on my third Bloody Mary.... I think its time to go downstairs a have a serious chat with that Yellow-Bitch of mine.....
By the way... last night we went to a local "Bingo" and we won something!!! (its a first!!!) :whoop: :oldhardlaugh:
francoblay1
The Spaniard
Something I forgot, If the terminal got hot enough to glow, it just might have Fubared the connection to the cable. possible ya need a new cable.
Yeah... I am working on all possible scenarios in my mind..... I just need to get my ass off the computer and go downstairs to get hands on with it.... pffffffffffffff
I might grab the little bike and go for ride instead.... I am not in a good mood this morning!
chubs
Remember Franco procrastination and masturbation are a lot alike, They're fun at the time:whoop:, but in the end you've just screwed yourself :job::yesnod:
