francoblay1
The Spaniard
Oh man, what would I do without you, Thanks for your helpThe only thing that would cause something like that to happen is resistance."clean and tight" remember!
I too did the red Locktite. I also had lock washer on it. Still came loose. Thinking about doing a wire tie to it.Yiiii-Haaaaa!!!! I can´t stress it enough.... "All Connections Clean & Tight!"
Negative Battery Pole was loose........ AND I had RED Loctite in them..... Always remember that these vibrations can loosen up ANYTHING & EVERYTHING!!!!!!
I´ve got the older Yuasa that I took off.... (then it was the VR) I will try that first.... Oh man, I am not looking forward to chase gremlins..... not today.....You got an old Yuasa ? Just buy a new one and be done with it
OK.... good morning..... I need coffee.... I thought it was a bad dream, shit.... going downstairs to work on it.....
Does it get hot under load, (cranking) or while it's running (charging)??
Cranking, probably crappy connection ,
Running, maybe overcharge? regulator?
You know the drill, check the simple things first.
Good luck buddy!
Cranking. As soon as I hit the start button it BURNS!!!Does it get hot under load, (cranking) or while it's running (charging)??
Good luck buddy!
Quit hittin that button and clean up those connections before ya screw something else up!! Okay now, that bit of scientific advise will cost ya one bottle of that vino!Cranking. As soon as I hit the start button it BURNS!!!
Thats why I didn´t go downstairs yet..... and I just oiled the 9mm..... or was it the 10mm that I should use... damn...Quit hittin that button and clean up those connections before ya screw something else up!! Okay now, that bit of scientific advise will cost ya one bottle of that vino!![]()
Something I forgot, If the terminal got hot enough to glow, it just might have Fubared the connection to the cable. possible ya need a new cable.Thats why I didn´t go downstairs yet..... and I just oiled the 9mm..... or was it the 10mm that I should use... damn...![]()
Yeah... I am working on all possible scenarios in my mind..... I just need to get my ass off the computer and go downstairs to get hands on with it.... pffffffffffffffSomething I forgot, If the terminal got hot enough to glow, it just might have Fubared the connection to the cable. possible ya need a new cable.
Remember Franco procrastination and masturbation are a lot alike, They're fun at the timeYeah... I am working on all possible scenarios in my mind..... I just need to get my ass off the computer and go downstairs to get hands on with it.... pffffffffffffff
I might grab the little bike and go for ride instead.... I am not in a good mood this morning!
, but in the end you've just screwed yourself
Take the battery post off on the neg side. Touch it back on. It should not spike removing or replacing cable. If it arcs then direct short on the posi side of some component.
Spark, yes no?
