MY EHC STILL WORKS GREAT !!! i know,, shocking
HOE ER
On my 06 k9 and I want to keep it that way.. (oh and yes I have the newer black base style with plug. Has anybody figured out WHY they are going bad,,, heat, vibration DUH ?? but are there any ways to prolong the inevitable ?? I remember awhile back someone was talking about putting foam under the mounts to help eliminate vibration. (does that help) And I have been thinking since the EHC unit sits directly behind the back exhaust that could definetely be a heat issue, so I am trying to figure out a way to move more air through there or put in something to block the heat. What ideas have you come up with to try to keep the good ones going ?? I have searched through the whole ignition forum and can find LOTS about F_ U_ ones but nothing really about trying to keep "good ones" GOOOD !!! Ive done the dielectric, and keep everything tight, but it SUKS worrying every time I get on it and leave the driveway, if THIS IS THE TIME... :(
HOE ER
Am I the last one left with an original EHC still in my bike ?? :)) seriously somebody must be in the same predicament I am.. I want to see if I can figure out why they are going out so often. I reeely think it has to do with heat and vibration so I am trying to eliminate as much of that as possible I am putting foam insulation on the surround (to reduce heat) and then putting a rubber buffer under it to absorb vibration. I have seen pics of bikes that the paint is cracked right behind the back exhaust due to heat, which is about 2 inches from the EHC,,, thats ALOT of heat. Any ideas ?? I need it to last until at least 12/22/12 when the world is supposed to end, and waiting for a wire plus wont seem like such a big deal :) or at least the wait time shouldnt be as long.. Any ideas would really be appreciated..
cwcrash
I still have my EHC on my 06 k9, I think your on the right track with heat and vibration. I bought a spare on ebay just in case,but I think I should try to improve that situation.
Svahna
sorry but if you have a black ehc it couldnt be the original?
I think that kind came later than your 06
francoblay1
The Spaniard
better pics
Gents,
I bought an imported from the US 06 K9, I have no idea about its history and/or any mods, etc.
Could someone tell me what do you see in these two pics, original EHC? etc. Thanks.
Please, someone tell me as much as you can from what you see here. Thanks.
BigDickPitBull
05 pit here.....EHC still going good. it is the newer version w usb port but i have had it over a year and 10,000 miles w no issues. I do all the work on it, rewired my new bars. no issues to date
Srodden
05 mastiff original ehc 5000 miles no issues. I did shrink wrap all the connections on backbone and battery compartment area.
1BADK9
Limited Edition Member
Original still ticking (knock on wood) but I am going to buy a WP and have it on hand for that dreaded day when it comes. Well I am guess I am going to get in line for a WP seems like they are a bit hard to come by these days.
Knuckles
Over 24,000 on my ehc. 07 K 9
Had a stall issue awhile back but nothing since so not sure if the first sign of it going.
Ordered the PDM a month ago for the hell of it...they are really backed up. Telling me I have an expected ship date of June 22nd. We'll see about that. I haven't had the best luck with BDMPP
08mastiff
12,500 on my stock one also. You have to wonder the goofy stuff people do on their bikes that could cause theirs to crap out. Maybe doing electrical work without disconnecting the battery or other things. Dunno, for now I am happy with mine..
PROFLYER
SWOLE
06 K9 here with EHC. They did swap it to new USB plug style and I have the most recent update....lots of 06 K9s it seems....
Sent from my DROID RAZR
gentlemant
hello, I'm from France, I have a problem with my big dog k9 2004, he did not start, I changed the thunder heart, then the starter, and he still does not boot, when I run the led case of thunder illuminates it nothing happens when I loose the starter the bike stops and there is a flintlock that comes from the candle, can anyone help me please? thank you very much
slam
Knock on wood still have the original on my '08 K-9 with 14K miles. Like some other members, I am going to order a wire plus just in case.
