Mechanical thing next to the belt drive???
V
What a tangled web you've weaved:roll:
As mentioned Idle should be 1000-1050 RPM. To low (around 900 and speedo will look like a christmas tree). Also to low will be low oil pressure.
Finn
Threaded part, next to the trans?
Sounds like your radiator cap.
Now that you've hammered it back on, how are you going to flush your coolant?
N8KAM
Just beat the carb with a hammer until it starts to idle down, this method worked for you already, should work again.
:roll: :roll: That is just what i was going to say :roll: :roll:
I liked the trans puddy repair also.. :roll:
And i thought i had a bad day today....... Just wait till he has to remove that cover....:rant: :bang: :angry: Can't wait to see that post..:lol:
Polak
ohhh this is too much fun... some of you guys need to lighten up... life is too short to be soo serious... grab a hammer and go fix something - i tell ya its gonna put you in a really good mood :2thumbs:
Vegas
Was this particular part next to the muffler bearing. If so, this part is indeed part of of the tranny. What you need to do is stop over at any local auto parts store and ask the guy for a can of transmission putty. Get the purple putty, it's stronger than the orange type. plus it looks better. Go home take the same hammer and beat the part back off and apply and heavy coat of the purple putty behind the cap and take the same hammer and beat it back on. This putty will stop the air from mixing with the oil and causing the transmission to shift on it's own. Good luck.
Best post I have ever seen on this site!!:roll: :roll: :roll: :roll:
Tim
Founder
Lifetime Supporting Member
After the week I've had...there is no way to make something up as funny as this thread! Suddenly-I'm feeling better about myself.
:roll::roll::roll:
Tim
Founder
You made my day for sure! :cheers:
First, I don't know what year it is... but I think you're talking about your clutch adjustment
if its older than it will look similar to this
Then the adjustment is on the primary side
If its a newer dog it will look like this
And adjusts under that cover
Either way this will tell you how it works....
http://www.bigdogbiker.com/forums/how/2025-how-adjust-your-clutch.html
HOWEVER, with opening posts like your first and using of the hammer... you may just want to put down the hammer and wrench, start using your PC mouse more to read around here.
Secondly, read this on your carb problem...
http://www.bigdogbiker.com/forums/how/4943-how-adjust-your-carb-check-jetting.html
C
chaingunner
Guest
Me thinks Polak gots a holds of somes hippies green.............
