Set screws are located on the bottom center of the headlight bucket the hole closest to the front of the bucket. I forget the size I thinks it's a 1/16 allen head. You may need to heat it up a bit to get it loose. use a hair dryer.This is a really stupid question but how do u get to the bulbs.It looks like it has a ring but i don't see any set screws
Take out the set screw on the bottom of bucket. Then remove the trim ring, if too tight try putting some rubber gloves on or putting tape on the trim ring to get a better grip. There is another ring under the trim ring and the bucket should come right out afterwards.This is a really stupid question but how do u get to the bulbs.It looks like it has a ring but i don't see any set screws
Thanks everybody.Can I get the bulb at a harley shop?Just had the exact same problem on my 2002 mastiff earlier this week. Just change out the bulb and you should be good to go. There is a really good how to page on changing your head light on the forum. Its step by step with pictures.
