Ok … I guess there is some confusion out there. I made this point in pictures number 5, 6, 7 and 8.
1. You do not add any material to inner workings or alter design or function pictures 7 and 8.
2. If you Change the dynamics of how the kickstand works it will no longer function properly.
So by your comments I can tell you read this. Now pictures 5 and 6 show that bdm did not allow for
prolonged wear on the strike point of the stand stop/lock area. The stand Bracket ( part bolted to the bike) was
designed without enough material to sustain the repeated use and load of the bike.
They over machined this contact point. When it wears it allows the leg “U” channel to pass beyond the
stopping point then “CRASH” down it goes. This action is further enhanced if the bolt is allowed to loosen.
The two combined “ wear plus Loose bolt” will accelerate your loss. The stand will not engage the bike will drop.
It is here that you are rebuilding the bracket (Part bolted to bike) the levers (leg) contact surface.
What you see in the final pictures is enough build-up contact surface NOT TO ALLOW the legs “U” channel to pass
beyond the (Bolted on bike bracket) stopping point. This fix adds more holding material to the (bolted on bike) bracket.
Not allowing the Leg top (“U” channel) to pass by. Even if the bolt loosens it will allow you a margin of safety.
To put it another way: Contact point will not wear allowing leg “U” top to pull past the (bolted to bike) bracket stop.
You have built this stop up. Look at the bracket . Do you see the detent in the bracket? This is where the stand needs to
align itself to be as new. You are restoring it to this configuration.
As to the comments about the stand knocking back if caught. You commented:
“sloppiness, so to speak, is by design until it has excessive wear”.
“What happens if you pull out and forget to put the kick stand up?”
“Does it fold up like the factory or will it throw you off the bike”
It is obvious I wasn't clear enough.
No. 1.. It will not wear out, like the factory incorporated design fault.
No. 2… it’s not going to wear and FALL DOWN like the factory.
No. 3... It will function exactly as stock just better and with long term dependable.
NO CHANGES are made to the DYNAMICS OF THE STANDS OPERATION.
If I chop my finger off in a blender do I buy a new blender and do it again?
Or do I not put my finger in the blender? You could have 9 more tries. I think
You might need to ponder that one.
If your happy repeating mistakes already suffered by others by all means continue doing so.
Good luck with that.
