Now ya got a trike..don't need em..WTH happened to my legs,![]()
Spyder bite him??They were torn off using reverse on the spyder![]()
Now ya got a trike..don't need em..![]()
I have to be able to get on it!!!!!! Ain't like I can whiskel, HiO Silver and it comes runningSpyder bite him??![]()
What a bunch of Meat Heads, you 2 will room well together
You keep spouting offI have to be able to get on it!!!!!! Ain't like I can whiskel, HiO Silver and it comes runningWhat a bunch of Meat Heads, you 2 will room well together
about how state of the art it is, and it doesn't even come when its called??
Not very high tech...
I didn't get that option, but it does have handle bars so you can steerYou keep spouting offabout how state of the art it is, and it doesn't even come when its called??
You look down the fill spout and the oil should come to the top of the oil tank, not the fill spout. When full and running you can see the oil flowing across the bottom of the fill spout.Thanks for the response, only question I have is how do I know it is topped off. I have no dipstick. I thought I remembered someone saying it needs to be warm and it should be an inch to an inch and a half from the top.
Maybe someone we know is regressing back to childhood..My daughter had a sled like that when she was 5
Different models and years varies weather to check on kickstand or upright. If you look at the 07' service manual some models are kickstand and some are upright. I believe it has to do with whether it has a dipstick or not and the different types of oil tank.Mine also is checked off the kickstand I believe the manual is wrong saying on kickstand
Different models and years varies weather to check on kickstand or upright. If you look at the 07' service manual some models are kickstand and some are upright. I believe it has to do with weather it has a dipstick or not and the different types of oil tank.Mine also is checked off the kickstand I believe the manual is wrong saying on kickstand
Well this horse has been kicked to death. He has an 03 Chopper, it is a different animal all together.
If you don't see a drop of oil under your bike it just means your not home yet.All I got to say is you know you need oil when your bike isn't leaking any....
Read it sloooooowwweeerrrIf you don't see a drop of oil under your bike it just means your not home yet.
Now where are we? Are we still at three quarts?
I'm trying to keep up but sometimes I get so confused.![]()
