Jetting a K9 w/straight pipes
Chip13
Just finished installing a set of Eddie Trotta C4 pipes on my '07 K9. No baffles so I was concerned about jetting. I was running a set of Mean Mother's using .031 intermediate jet and .78 main jet. Ran great but a bit mild for looks and sound. I stuck with the .031 intermediate but bumped the main to .080 and it runs perfect. Plugs look clean also. FYI for anyone searching through the jetting threads for specific advice on jet sizing.
linemup
i just cut 4.5 inches off of my vand h 2-2's and now the damn thing cuts off when i "blip" the throttle................lol was thinking about taking baffles out but not sure now
LamboV12
Linemup - did u try increasing the accelerator pump screw? Make it start sooner and should take care of it.
linemup
lambo_ it turned dark before i cld get manual out to see . knew there had to have been an adjustment just went to a 32...........wait 31...................inter jet. just now learning which screw does what................gotta look at pics to see.............use to auto carbs not bike carbs but its all the same. just a diff location. think i saw it in the book.......i hope . leaving for thunder beach friday so need to get it right.
LamboV12
I been running a Makuni for last few years and been some time since i did a SS. Usually clockwise. You want the squirt of fuel to begin sooner. Start the bike turn it quarter of turn to right, blip the throttle and see what it does - cant hurt anything at all while your doing it. If better, turn more, if worst, repeat in opposite direction. Keep the bike idling the whole time.
Chris04Masitff
How to adjust your carb and check jetting
search for this thread. its a sticky .... works absolutely perfect......did it this past sunday ... took away lil stumble i had.
LamboV12
Just in case your not sure - as u face the carb its on the right side at the back (inboard) side. Screw is on top and i think it sits at an angle - still have mine but burried in the garage
