jerking and noise when down shifting
rebel dog
2005 117 Chopper started jerking when I down shift mainly when I get to second and first can also hear noise from the primary area at that time. ...thinking the clutches might need replaced because while sitting at red lights it slightly pulls forward while the clutch is pulled in...any suggestions
rebel dog
Removed the cover and where the clutch is there's what looks to be bearings in that clutch area...do I take those 4 bolts out and remove all that
bearman
I was able to fit a socket on my clutch hub nut by just taking out the throw-out bearing. Just take the snap-ring out and it the throw-out bearing comes right out. Not the tiny 1/2" outer snap-ring, but the bigger 1-1/2" inner snap-ring. The tiny one holds the pivot in the bearing, the larger one holds in the bearing. This way the whole clutch will stay together.
First I spent an hour looking for my old snap-ring pliers, then spent another two hours trying to get the snap-ring out without them (never did find them), finally went to the hardware store, bought a new pair for about 15 bucks, took about 40 seconds to get the snap-ring off with the pliers.
If your clutch hub nut is loose, don't just tighten it. Take it off and put some locktite on it before torquing it back down. Mine had a lot more than a couple drops on it, so I was liberal with the locktite when I put it back on.
And of course the hub nut has backwards threads, so lefty is titey on that one.
BadBrad
2005 Pitbull
While you're in there, I would pull the clutch basket and inspect it for cracks. Like Kurt mentioned, many have had the basket break, especially on '05 models, including myself. Also, keep in mind that the clutch hub nut has reverse/left handed threads.
