Install/Repair Gas Cap Paint Saver; Bubbling Paint
Normally, what I have done in the past, is if your ordering from Wild Steed Worx or HDM, I send it to them, and they throw it in the box. I'll look into it. What town will it be going to?
OlivaRider
It's just a flat piece of 316 ss, slightly curved to fit the top of the tank. It's then polished to a shine and glued to the tank.. I'll see if I can find some more pictures.
Thank you very much. I have one last question. Do you seal it afterwards with an O-ring or a flat gasket?
What I'm actually interested in is the underside of the disc. It isn't visible in the photos.
Here's the instructions I send out with it, maybe it will help you understand how it works.
INSTRUCTIONS
  • Remove stock paint saver (SPS). Remove the rubber gasket from it and throw it away. It will not be reused. If you don’t have the tool to do it, you can get one at
www.bigdogpartskingpin.com or call Donna at 620-257-2009
  • Stick a rag or piece of tape in the hole, to prevent debris from falling in the tank, and clean and vacuum out hole.
  • Scrape all loose paint from around hole, down to the metal. You may have to cut out some loose bondo.
  • Use some JB Weld to reseal around the hole, sealing the paint to the metal, making it as flat as possible. Let dry completely.
  • Fit the new paint saver ring (NPSR) on the top of the hole and mark which direction it fits the flattest. Ring can be adjusted with a rag and rubber mallet. (but not on top of the tank)
  • Remove NPSR, and run a ¼’’ bead of Ultra black silicone around the tank hole, and then press the NPSR in place. A little bit of the silicone will flow to the inside of the ring, that’s ok, do not wipe it out. It is part of the sealing process.
  • DO NOT add any silicone to the SPS, when you screw it back in the hole. Hand tighten SPS, making sure the NPSR is centered.
  • Leave the gas cap off for 24 hours, so everything can completely dry.
  • If you have any questions, or dissatisfied in any way, please call. 573-247-3508
Thanks,
