Inspection cover
I am Thor
Got a new gasket but noticed at the top of the cover has a groove and on the primary has a raised line across the top new gasket not made to except that where can u get rubber one like r in there ?
I am Thor
Maybe trim the cardboard gasket around raised piece or grind it off so you don't break the ears off cover ?
Nukeranger
Nukeranger
If you want to avoid breaking the ears off, use half the torque called for. It works for me and no leakage. You do have to recheck the torque after riding a while.
Use gasket sealer and if it says 120 inch lbs use 60.
Nukeranger
I am Thor
i just put my rubber ones back on with some blue silicone . did you notice the grove and ridge at the top of the cover i realy think that is what is breaking them i torgued mine to 9 with no problems
1BADK9
Limited Edition Member
I broke one the next time I made my own cork gasket and snugged very gently. Figured if it leaked I would tighten a slight bit more, no leaks....no break. Torque values on covers is a waste of time in my opinion, tighten enough to not leak without over tightening, I don't need a torque wrench for that. :cheers:
