Ignition problems - no spark
Titan7101
I have a 02 Bulldog....the LED on the module flashes like it should, so the pickup is good, but I have no spark. Coil or plug wires? Any advice?
stlmikie
I wish I had more money.
If it's not hint on either cylinder at all based on the info you gave it's the coil. You are talking about the ignition module light right?
Pull the coil cover and ensure one of the coil wires didn't break off
Lamar
No Spark
I too have no spark at the plug. When turning over (new battery) the red light on the unit flashes. A local mechanic came by and said just eliminate all of the electronics and put in a crane ignition tapped to the main harness....any thoughts on that, seems too simple. I guess that would eliminate the computer access, but I am not sure I care?
