Had the tires dismounted from my wheels and the bearings pulled. I am now removing the hubs in order to polish and clear the rims and hubs.
We will start with the rear wheel. Remove the bolts holding the hub together. These are on tight and with red locktite. Had to use an impact to break them loose.
The rears on my '06 K-9 already had the index marks on the inside. Index marks allow you to put the hub back on exactly as it came off. Also see below the rust from the bearings. The bearings were trashed after 8000 miles. I didnt keep the bearings as I forgot them at the dealership, but the inside number 2 bearing was frozen, only the outside number 1's actually turned. See below rust issues on the axel, and the index marks above the bolt holes on both the left and right side.
Here are the index marks on the wheel & on the hub
And the finished stripped down rear wheel.
Now on the front wheel there were no index marks at all. I would suggest marking the hub & wheel with a marks-a-lot on both hubs before removing the hub bolts.
I then stamped my own marks on the inside of the hub & wheel for future use.
One portion of the hub on the front came off easy (cone shape side). The other side was a pain in the A#@. Had to spray lube on it to loosen it up then twist it back an forth till it broke free. That's why the black marker index marks are important. Once you twist and pull the hub off you will have no idea exactly how it lines back up to go back together (trust me on this).
See below one side has some markings, but no markings to match on the wheel. I stamped a mark on both after removing.
Remove the wheel weights with adhesive remover, pull the stems and rims are ready to polish, chrome, zoop, etc.
