How to re-apply rubber to Pegs and Grips
Dragonslave
I don't think anyone has done this on here that I know of so I thought I would post this How-To.
I have to Spike Chrome Raptor pegs and grips. I love them and they look cool but the rubber was coming off from use. I tried to find the replacement rubber to fit them but I couldn't. So if any of you are under a budget like me and don't have the spare $600 laying around for a new set of grips and pegs, there is an inexpensive fix to re-applying rubber to your pegs. Here is what I did:
1-Purchase at least a 22 oz can of Plasti Dip (if you can get a larger can do it). You will need 4 coats of this on your pegs so the more the better. I got mine from Amazon for $14 but you can pretty much find this stuff at any hardware store.
2-Remove your pegs and grips from your bike and tape up the areas where you DO NOT want rubber applied.
3-Follow the directions on the back of the Plasti Dip and coat the surface of the peg/grip until it looks like the below picture. It is important to dip slowly to avoid any air bubbles. Repeat this process for at least 4 coats. Let the Plasti Dip dry for 30 min between each coat. **The first coat will look thick but trust me it dries a lot thinner than you think. Allow 24 hours to completely dry before continuing to step 4.
4-Take a razor knife with a NEW blade and carefully cut the edge up against the step up around the entire peg/grip. Make sure and cut all the way through to the metal. It may take a few passes to cut all the way through. **Take your time with this step. You want to make sure you cuts are straight and even. If not you will have to remove the rubber and start over.
5-Peel away the tape and excess Plasti Dip and here is what you are left with. A fresh coat of rubber gripping.
Marky-Marc
Great Write up Dragon! Love it. I actually like the look better than the rubber!!! Great job!!!!
Replacements can be found here though for $25 if anyone is interested. DLXPRODOX is the manufacturer of all those pegs I believe and the 'rubber' parts are actually made by a company called Avon.
http://dlxprodox.com/DLX/index.php?cPath=37&osCsid=2c71ba42265afb343d9afce26e866e3c
I've had mine laying around for a year or so now.....
Dragonslave
These look like they might be a pain in the ass to get on. Have you tried to install the replacement rubber?
Twisted
Hey Marc, if you didn't put the rubber on yet, could you measure the inside and outside diameter of these and the length. Looking for something for a little project. Thanks !
