in the bracket? If we want a photo, the code is typed as 'IMG' for Image or the photo.
Shortcut Key Capture 1 = I'm going to right click on franco's signature photo. A popup window occurs. I want to drill down to "view image" and click on it. I now move up to the address bar at the top with my mouse courser and click on it. I now copy the blue line by holding down Ctrl and pressing C once. If say my mouse did not turn the address blue, I then hold Ctrl down first, press A, then C. I do not let up on the Ctrl key but hit A and C to copy and C is ready to place in between a bracket.
Key Capture 2 = I have my photo address saved when I hit the combo Ctrl + C. Meaning, I can hit the shortcut to capture the photo line and then come back on this message pallet, hit the next keystroke to set the brackets in place. I now hold down Ctrl again in the message pallet, press U. I now have a made set of open and closing brackets with the U for underline. I remove the U's and insert the code letters "IMG" into both brackets. I then move the courser into the middle of both brackets, hold down Ctrl and press V. I should see franco's jpg address in the middle of those brackets. I am ready to send in a photo with my message.
Setup = Here is franco's photo address:
i1255.photobucket.com/albums/hh632/lobito111/WINNER_zps075cae9e.jpg.
http://i1255.photobucket.com/albums/hh632/lobito111/WINNER_zps075cae9e.jpg[img] Take note that I removed the http so the system does not auto-bracket this address line. Also using the same full address, I eliminated the closing forward slash so you can see how the brackets are butted up against the address line. See how the f-slash is missing in the closing bracket? All you need to do is add the f-slash to make the photo happen.
Bracket Glitches = This is also a way to troubleshoot why you see your brackets and address, but no image? Your coding is off. Either you did not butt up against the address; you didn't add the closing slash; you spelled the code different in the other bracket. It does not matter you use caps or low letters or a combo there of. As long as the letter codes spell the correct coding, she'll work.
[img]http://i1255.photobucket.com/albums/hh632/lobito111/WINNER_zps075cae9e.jpg
