HELP WON'T START JUST FLASHING INDICATORS
Chazzz
Went to fire up the dog this morning and just all the indicators were flashing cant beep horn or anything any idea what's wrong now was only riding it good as gold last night after replacing new spark plugs ran like a dream parked it up put on the smart charger and now this problem help :angry::loony::bang:
Nukeranger
Nukeranger
Check the battery voltage. Did you leave the lights on? Sounds like a battery problem after a fun night. Could the battery charger be malfunctioning? Just a few things to check since the indications are pointing to low battery voltage. Does the head light come on bright?
Chazzz
its a brand new battery about 9months old now but always been on battery tender and had no probs till now
cavcom278
THE COMMOMAN
Check the ecu connections mine did the same think. Cleaned and reapplied dielectric grease no more problems.
cavcom278
THE COMMOMAN
Inside the electrical covers. Remove your seat should be on the inside right of the battery. Do a search of my posts the guys on helped me troubleshoot my k9.
Knuckles
does the horn beep when you try to start?
mine would do that before I went with the pdm.
usually when the bike was cold or batter weak for some reason.
Rottweiler
Chazzz did you every find out what it was?
Hi I'm kind off new here, just bought a 2004 Chopper it ran good for only one day. Then the same thing the oil and neutral light just flash when you turn the key on? If you hit the starter even it pulses? At first you could just let it set and after 5 - 15 minutes it work ok again. Now that is all it does. What did you do to get it running again? Thanks
Chazzz
Thanks heaps I done what nukeranger said disconnected the battery and went to the gym come home put it back on tedious tricky little plugs to do up lol and it started fine went for a ride so far so good I'm back up and running pheww any ideas why it would of needed resetting I changed plugs last night put new 1s in and that's all
BigDogBro1
Made in the USA
Don't forget to add dielectric grease to the connector pin area.
Disconnect the battery when you work on any electrical on these bikes.
