cavcom278
THE COMMOMAN
Ok so heres what i found today. Was doing a look
over because i saw "JUST 1 DROP" of "OIL" on the carport floor "my dog has never leaked a drop of oil before i saw it today "it was under the front of the primary case so i started looking. As i really started traceing the line it disappeared up behind the inner primary so i started looking at the motor."I guess the wind flow raps around the rear cyclinder and pulls the oil forward I GUESS?" I started in the front and worked my way around the the rear and low and behold the rear base gasket is buldging and is cracked and pushing a little oil out the crack. Well i guess i will be pulling the rear jug to replace the gasket and doing a " FULL CLEANING AND POLISHING OF ALL MOTOR PARTS" but heres the real question..... Do i need to go ahead and pull down the front jug down at the same time just for good measure and replace all the gaskets so that i know everything is good to go? I'm thinking yes and doing so will be a good experance for me to learn more about my dog. Just wanting some info from everyone here and what there experances have been in doing this to there engines. Just looking for some suggestions from those that have done this before. Also thinking of doing the cam upgrade and roller rockers at the same time just for good measure. Hoping everyone will please chime in and give me there past experances on this subject so i can complete this mission RIGHT and many thanks from the "COMMOMAN"....
"YOU CAN TALK ABOUT US / BUT YOU CAN'T TALK WITHOUT US" Anywhere Anytime The Commoman gets through"
