bigdogjohn
Headlight keeps burning out 2004 chopper? Any help.
2X but I'd check the VR first just to make sure. Heck, I've got 5 of the Kaptins LED bulbs now! :up:The Kaptin has some swell LED lights. Super bright, and they don't burn out.
Wild Steed Worx & Services, When the road is your trail
Yes for sure, keep checking to see what's making it blow.
Make sure the wires aren't burnt inside the bucket, and touching each other.
I had one in the shop several years ago that kept blowing bulbs, and found a cracked bucket. I guess the extra vibration was shaking the elements out of it.
And yes, if the VR is going, the headlight will be the weakest point for the extra voltage to show up.
Yep,Yep...X2!!!!!!!!!!!!! And Curtis from WSW has a Updated Headlight wiring harness with Heavy-Duty Ceramic connector,and a couple different Bulb Options also..........:up:
,2X but I'd check the VR first just to make sure.
yes check for vibration, I put a soft rubber grommet on my light base .(has it's own ground)
2k , no burn out on a vibrating pitbull
Yeah Buddy, I love my LEDThe Kaptin has some swell LED lights. Super bright, and they don't burn out.
Huge differenceAs mentioned b4... check the bulb... and check THIS out too :up:2007 mastiff will not go to low beam any ideas.
