I sent my heads out to WFOLARRY (Larry's Motorcycle & Machine, Inc in Oak Lawn, IL at
wfolarry@aol.com) to be worked on. The heads now have the 2.00 intake and 1.605 exhaust valves, ported, milled .030, Squish Groves, CC’d, flow tested, new valve guides, Bob Woods W188-1200-10L valve springs ($280). I use the Woods W6HF 650 lift cam ($350. The machine shop cost was $659.00.
The Rocker Boxes you will have to get as a kit, a good source would be Nelson at
sales@wbcycles.com. You will need
BDM 100-00083 BG PBG Rocker Box Set, DC
BDM 100-00081 BG PBG Roller Rocker Arm
BDM 100-00080 BG PBG Shaft, Rocker Arm
BDM 100-00414 BG PBG Gasket Front Tappet
BDM 100-00416 BG PBG Gasket Rear Tappet
103-000067-00 BG PBG Kit Gasket Top End
All of this goodies ( S&S Rocker Boxes kit ) come out to about $1100.
You might be able to get somne on E-Bay, but will they fit right.
Hope that helps
Carlos
