Fork seals leaking at 1300 miles :(
Should have read your last post more closely.
Do you have a couple of curved or angled dental picks so you can get under the bottom edge and pull up on it.
badyellowvette
I will have to work on it, I do have dental picks but haven't tried them yet. It's a pretty tight fit. I have a bearing puller at work I might try if it will fit into the tube.
Do you sell just the upper bearings? Don't want to try to reuse it after I get it out.
If I have to the Harley shop is 60 miles away I will be within 30 miles of it tomorrow.
As long as you don't trash it you can reuse it.
Put a little heat to the aluminum just before you pull on it with the picks and it will pop right out.
I haven't started stocking individual parts.
