FORK BRACE ?
It wasn't there...
But yeah that would work... that is similar to the stock setup on a long BDM. But the bdm mount is bolted to the lowers and not clamped like that one
I still think you should adjust the fall rate on your forks. You don't have a long front end and with 2500 members here you are the first to bring this up so might just be your trees are loose.
RADAMS445
RADICAL
Ray I will not dismiss that possiblity as well. Also not having driven a 38 degree rake bike for any true time frame-well-drivers ability might be a factor.
Check these guys out, they have a ton of different ones that may work. Just measure your lowers and figure out the center distance. Maybe you would get lucky and just have to bore out the lower leg portion. The fork brace I have (gas posted) would not work with the fender. However if you wanted with a little fab work would work inside the fender.
Harley Davidson - SuperBrace - The Ultimate Fork Stabilizer
