Perfect, thank you!Here is the one you want.
Happy happy happy! I just ordered the original Kerker from bigdogpartsking, Donna is absolutely sweet.One more pic
Just pure stupidity. I was trying to get the exhaust flange retaining rings off the old headers, but not having the correct tool I was using two pairs of vice grips. Something slipped, I'm not quite sure what happened but I was bleeding quite impressively.Good news! :2thumbs:
Now.... what's all about the "pool of blood in the shop"???
Thanks for the tip re: the spacing. I don't know if I'll have this issue or not... I have a nicely fitted 3/4 inch aluminum spacer on the transmission, seems maybe it was meant to be there for this exact reason. If not I'll be sure to grab the spacers and bolts as you specified.John, I was just working on my bike and noticed that I had to space out the mounting plate that bolts to the transmission. It takes two 3/8 I'd by 3/4 inch long and one 5/16 I'd by 3/4 inch long spacers. That will move the mount out enough to miss the bolts that hold the swing arm bushing in. You will also need longer bolts and some blue thread locker. I got my hardware at Menards. They have a good selection of chrome stuff. Good luck. I hope you like the new exhaust.
Oh and do a plug check to make sure they don't lean your mixture out.
Great, thanks!Sounds like the spacer will be just fine. The long bracket should come with the exhaust.
