Engine periodically sputs
chubs
His problem lies in his Suckdenator......
:hi: My pit has a habit of stutterin at about 60 too! :oldconfused: twist the grip and she picks right up and smooths out.:yesnod: I kinda leanin towards a fouled suckdenator also!:whistle: Already replaced the blowfer valve, and all electrical fluids, with no change.:oldlaugh: Yep, it's gotta be the suckdenator! :job:Ya don't happen ta have 8 or 10 layin around on a shelf, do ya Marky?:oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh: P.S. lookin for a red one ta match the frame! :drool: :oldhardlaugh::oldhardlaugh::oldhardlaugh:
Marky-Marc
You have to re-route the SUCKDENATOR valve and tube BACK into the frame dammit JIM!!! It's leaking into your fucking CARB now????!! Then re-tune your air/fuel ratio on your carb!!!! Your mechanic fucked up bro!!!!! Get a new mech!
chubs
So, ya think it's possible that the blowfer valve might be installed sideways, causing the electrical conjunctions to plug up the orifices in the frame?? Shouldn't the suckenator unplug that mess?:oldconfused::oldconfused::oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh:
Marky-Marc
Try changing the orientation of your spike air filter. If its forward, point it up, and vice versa....and check if the auxiliary bowl vent screw has been removed? S&S recommends removing it when changing breathers.
On a serious note, Harry is correct. I've been running mine straight up for as long as I can remember....if the air filter was just thrown on, and the bowl screw was not removed, it will cause this issue.
