fuelman97
Been learning a lot reading and researching the sight. Bought a 07 k9 a couple months ago, I've been doing mostly service and preventive maintenance. Been having an occasional start issue. Pick up slam button from WSW . I just got done putting dielectric grease in all connections including EHC . So here the question. Hook the battery up, and start doing a system check. No left rear turn signal. After about 30 seconds it works. Then I lost the low beam, cycled the key headlights back. Tried to duplicate the problem, but no luck like the starting issues.everything works as it should. Any ideas?
