Voltage on the battery does not climb at throttle, it actually drops. I saw on some of the other threads that the voltage on the stator should be about 20 at idle and about 50 at about 3000 rpms. Is that wrong cause that's about where mine is. Voltage at the circuit breaker is the same as the battery at the second post, but it has no current at the first post where the wire from the vr is connected. I would like to replace the circuit breaker with an in-line fuse since I read that those are garbage anyway. Its also a lot easier to know something is wrong when you see a blown fuse.
