dingo
First 50
Having an electrical issue and wondering if anyone else has experienced or has suggestions to resolve:
06 K9 - 16K miles - installed one of the early Low Down Chop Shop WirePlus units 3 years ago - no issues since install - original speedometer - original ignition module - original crank sensor - original VR - new plugs - spark plug wires are not new but test good (visually and ohms) - new battery - new coil
About 2 weeks ago, I noticed that the tachometer was reading correctly but intermittently the brightness began regularly pulsing between the day (bright) and night (not as bright) settings - alternating bright and then not as bright about once every second.
About 1 week ago, I was riding along at 70 miles an hour and lost spark to the front cylinder. Made it home and followed the diagnostic flow charts - based on the testing, it appeared that the coil was bad so I replaced it. Bike started and ran fine for 5 minutes and then I lost the cylinder again. Battery had been on a tender but was not holding a charge (realized it was 4 yrs old) so replaced it last night.
Bike now starts and seems to run smoothly (only ran it on the lift) - charging correctly at 14+ volts - but the tachometer is now pulsing all the time.
I still have to check the connections to the tach under the tank, but, since the common component between the tach and the coil is the ignition module, I am wondering if this pulsing and loss of spark (even though it runs smoothly now with new battery and new coil) could really be the result of a bad or going bad ignition module. Or, am I missing something else ?
Appreciate any input or experience.
Thanks in advance.
Thanks in advance.
