EHC R.I.P problems
Brew
I haven't installed mine yet but, I will say that Jason and Matt will stand behind their product. After all the debate about misplaced pins when they first came out I sent mine back to KMW and Jason has built a bench tester to test these systems for that problem. They tested and returned mine at no charge. Thanks again Jason..:2thumbs:
So yours was pinned correctly or did they need to re-pin?
numbers
I had this issue after working on my Vintage Sport a few months ago. Replace EHC with updated one, still the same thing, then noticed the Ground wire was broken at the lug. All went well after that.
The power was showing ok until I tried to start then nothing. Ground was getting through till it needed better current and failed.
Good Luck.
