Refer back to post #9.
This would probably be the cheapest way to go without changing the harness.
Contact Matt Moore at bigdog.net. I am pretty sure he is the only person that has the correct replacement EHC for your bike. Like $600.Can someone give me a number of a company or person that can sell me what i need to get my bike going?
				Not for EFI bikes however. So pretty sure BigDog is his only option.You may want to give this shop a call . Barnes Performance Cycles is reputable and they are coming out with a new EHC with wiring and lifetime warranty for $600 . Worth checking into!
Big Dog wire harness and controller, EHC w/ lifetime warranty
Big Dog electrical wire harness and controller: A true plug and play kit to replace your faulty factory EHC. 100% Built here at Barnes Enterprise, LLC using made in USA parts. The only electrical harness kit on the market that comes with a Lifetime warranty. Optional brake light Flash/ strobe...www.barnesperformancecycles.com
Hmmm…I replaced it at least 4 or 5 years ago and paid around $600-650 for it from DOC’s. Axel’s was fairly new and DOC’s was wired for the lo fuel light for the EFI Bulldog…..Just visited DOC’s website and the EHC is indeed advertised at $1200 now, so I would look around too, given the price difference and high praise for Axel’s.The only problem with a DOC replacement is $$$. I bet you paid well over $1200 for the unit…. Basically could buy 2 from BigDog for one of his…. To each his own.
Not sure the cost of other ones, after taxes I paid $791. Ordered from bigdog.net. But it was simple and worked since the orginal EHC finally failed
2005-08 EHC REPLACEMENT SYSTEM – (ALL CARB MODELS - W/ STOCK WIRING)
 Glad you got your bike back.
I totally agree with Rottweiler. Upgrade the VR & add a inline fuse between the VR & battery. Curtis will hook you up. You can check with Andrew at barnesperformancecycles.com also. I do believe he is manufacturing EHC for ‘05 & up at a reasonable price. Seem to recall around $600i will see when he replace to my email and or text , thanks
No worries. I’m sure you are anxious to get answers but it takes time here. People don’t check in every day and there’s even less of a chance the right one will be checking the post when you need it. But, if you’re patient then you will get the answer you need here. Best of luckI am pretty new at this, my apology's
