Well, since I've done it twice now guess I'll say what I did. Ok, take the pivot shaft bolt turn counter clock wise and remove, then the round thing with the 2 flat spots turn it counter clockwise also till you can safely turn the belt (assuming you have removed the rear tire already) 90 degrees and slip it between the round thing with flat spots and the pivot shaft bearing. also make sure your front pulley cover has been removed so you can get the belt of the pulley and that should remove the belt from being trapped by the frame. As far as the rear tire, loosen both wheel alignment allen set screws, remove the axle covers, remove the nut, slide the axle out, remembering or marking which spacer goes where and how they go in, the flat side verses the lipped side does make a difference, once axle removed work belt loose of rear drive pulley and remove belt.
Quick way of removing belt, cut it. But to put another one on do steps above.
