whatever01
I noticed that I have a notch in the ribs of my belt and a wear mark on the top of the belt on the far rt. edge of the belt, when looking at it from the rear. I even had a pile of melted rubber on the lower swing arm area under the front belt cover/ clutch area. The belt seems to be rubbing on something under the cover, it is riding all the way over on the rt. side of the pulley. what the?
When you look into the cover you can see these nubs molded on the inside of the cover, I am wondering if the belt should be centered on the front gear or what.
