You could try installing the low effort 9 plate clutch set up that BDM went to in 2009. This would be a clutch pack (steels and fibers) and the inner and outer ball ramps.Thanks... I am full of questions...
I plan to order this now.. but have another question. Is this the actual hydraulic clutch minus the master cylinder?
Will this relieve my cramping?
Once they fabricate this thing is it just a bolt on?
Hi,I'm going to try a slave cylinder made by Magura that installs in the same location as the cable on the pulley cover and still uses the ball and ramp. they look pretty slick I have had them on my KTM dirt bikes, you can pull the lever with one finger.
Is this sold by BDM? Where can I find it? Anyone know the part number?:flag:Hey Black rider. Your bike already has the rsd. What you need to help with the cramping hand would be an easy pull ball and ramp. Something you could install yourself. Easy peasy.
Ray,You can buy the unit and have a local shop do the machining and install it for you.
You can ship your cover to use and we will do the work with about a 3 wk turnaround depending if you want it chromed.
If you in the area DMC can do it all here for you inclucing installing it.
The unit comes in standard, polished or can be chromed. YOur cover will need to be re-chromed after machine work.
Website will be updated today to reflect all this and there will be a price drop.
:2thumbs:
