You may also want to check or replace the Check Valve on the hose coming from the rear head to the air cleaner. The white side should face the rear head. Clean it or replace it :2thumbs:Sounds like the check ball in the oil pump is leaking by. Pull it and clean it and see if that stops the leakage. The S&S manual has the description on this.
Sent from my DROID RAZR using Tapatalk 2
Not sure what year Pitbull he has but if its 04 and earlier he has a different breather setup.You may also want to check or replace the Check Valve on the hose coming from the rear head to the air cleaner. The white side should face the rear head. Clean it or replace it :2thumbs:
Carlos![]()
Since you have the older set-up, this should be your first step.Sounds like the check ball in the oil pump is leaking by. Pull it and clean it and see if that stops the leakage. The S&S manual has the description on this.
