On the lift with no weight that would not be uncommon to still have a little tire spinning and clutch fully engaged. Once on the ground just the weight of the bike 600+ LBS keeps it from rolling forward. You're 04 & Earlier is 1/2 turn back standard Harley. Different than the 2005-11 models.Yes thx. I tried it back to zero or basically as soon as it touched. Still had movement when pulling in the clutch when on the lift in 1st. Was just wanting to see if bdm7250/( Doug I believe) ever had a issue with his open due to the basket & clutch pack being dirty and causing a issue with the clutch slipping.
