RoadmaxRoadmax or American standard trans???
Bobby,1) Check the clutch adjustment.
2) Check for any metal in the fluid when it is drained.
3) Check for bent shift fork or fork rod.
4) Get back to us and let us know what you find.
Thanks, I will.1) Check the clutch adjustment.
I get it Sven, but it also grinds going into 3rd. What say you?Can we catch N easily? No - Warp plates or certain pressure plates need adjusting.
Can we shift faster than what we are doing now? Yes. I need to move the foot more secure into 3rd.
I had my clutch system adjusted. No change. Well now, here is where the center basket is still moving or say a plate is making it spin up = Gear grind.
How can I stop this?
A. Start out in 1st with a dead engine so you do not grind with a running engine.
B. Live with it = Normal if that basket keeps moving with the outer basket.
