RobV10
I need a little tip in regards to adjusting my clutch pack. I tightened the bolt until I felt resistance and then backed it off 1/2 turn. I then tightened the lock nut.
I find that my dog won't start unless it's in neutral (tranny cold). I guess the clutch isn't fully disengaging when I pull the clutch lever. If I have her warmed up then this isn't as big of a problem.
Also, when I shift to first the bike lurches a bit. I expect the bang and a small amount of reaction, but the bike actually lurches forward about quite a ways and it even stalls from time to time.
I've tried to adjust the clutch pack again using the same method just in case I didn't tighten the locking nut enough or I adjusted it wrong but had the same results.
