Clutch hub nut
I have a stubborn clutch hub nut, is it right or left hand thread?
TNX...
It's backwards. Reverse thead. I use my 12" extension wrapped in a shop cloth to wedge in the chain to lock the primary up to remove and install this and the front sproket nut.
Gabriel
Thanks, so it's left hand thread.
The clutch plates are out so the rag thing won't work, I have a impact, tough
Gabriel
I installed the Balance Masters clutch balancer (already installed the crank balancer).
When I was removing one of the four nuts on the pressure plate I noticed that the nut just spun so I used a impact to spin it off and it came right off but the problem was the bolt that holds the inside piece was loose so I pulled everything off down to the inside cover, pressed the hub out and secured that bolt with lock-tight and checked the others.
I guess it's was not a bad idea because now I know it's right and the clutch hub and basket looked brand new.
Post a picture of these balancers you are using.
