PapaStein
Hey y’all.
So went for a ride with a good friend the other day and my clutch cable broke. I ordered a replacement that I thought would be of good quality like my original. And it turns out it was not. The housing was shorter and slightly smaller in diameter. The coating was not clear but milky white and the braid underneath does not appear to be stainless steel. The cable itself is not Teflon coated like my original. The adjustment was not in the same place either. Due to the housing being shorter it looks like it’s being stretched tight in a couple places. The adjustment is up near the fuel tank where it was down right after the frame turned up and got straight. The cable itself I have adjusted 5 times since installation and it needs adjusted again. Even right after adjustment it’s like the cable stretches so much that it doesn’t completely disengage the clutch because it still wants to roll. Also now I cannot shift to neutral unless I turn the engine off. When I put it in gear it like hits like clunk really hard and wants to start rolling. It’s like it stretches so much that it doesn’t travel far enough on the other end to completely disengage. My original I could get neutral anytime anyplace with no issues. So if anyone has experienced this and knows where I can purchase one like my original I would be grateful if you would point me in the right direction. Any information is appreciated.
