Clutch Cable issue.
PapaStein
Low and Slow!
Hey y’all.
So went for a ride with a good friend the other day and my clutch cable broke. I ordered a replacement that I thought would be of good quality like my original. And it turns out it was not. The housing was shorter and slightly smaller in diameter. The coating was not clear but milky white and the braid underneath does not appear to be stainless steel. The cable itself is not Teflon coated like my original. The adjustment was not in the same place either. Due to the housing being shorter it looks like it’s being stretched tight in a couple places. The adjustment is up near the fuel tank where it was down right after the frame turned up and got straight. The cable itself I have adjusted 5 times since installation and it needs adjusted again. Even right after adjustment it’s like the cable stretches so much that it doesn’t completely disengage the clutch because it still wants to roll. Also now I cannot shift to neutral unless I turn the engine off. When I put it in gear it like hits like clunk really hard and wants to start rolling. It’s like it stretches so much that it doesn’t travel far enough on the other end to completely disengage. My original I could get neutral anytime anyplace with no issues. So if anyone has experienced this and knows where I can purchase one like my original I would be grateful if you would point me in the right direction. Any information is appreciated.
PapaStein
Low and Slow!
Hey y’all,
I did go to the Barnette website but I’m gonna need a little more assistance. I did not find BigDog in the list of manufacturers and everything I searched came up black cables. Can you point me in the right direction to find these on their website or do I need to call them?
Chong
U-235
Another comment.. if your clutch isn't holding adjustment sometimes the nut holding the clutch basket to the trans shaft could be loose and backing out . You adjust clutch and nut loosens more and your back out of adjustment. This is the nut behind the pressure plate, not the nut that locks the clutch pushrod adjustment set screw. More common on 05 and up but my 03 did this. Red loctite, 80ft lbs LH thread. Some use more torque then OEM spec, particularly 05+ Use your own judgment on that.
PapaStein
Low and Slow!
Another comment.. if your clutch isn't holding adjustment sometimes the nut holding the clutch basket to the trans shaft could be loose and backing out . You adjust clutch and nut loosens more and your back out of adjustment. This is the nut behind the pressure plate, not the nut that locks the clutch pushrod adjustment set screw. More common on 05 and up but my 03 did this. Red loctite, 80ft lbs LH thread. Some use more torque then OEM spec, particular 05+ Use your own judgment on that.
I appreciate that thought but it was fine until my original clutch cable broke, never any issues after I did the adjustment myself immediately after I purchased the bike which was probably 4 years ago at least. This cable just seems to stretch a lot on the pull which doesn’t move the actuator far enough.
bikeone
Hey y’all,
Enter in contact via phone 805-642-9435 and tell them what model you have.
You will get what you need
They are very friendly and have real good Quality. (Lifetime warranty)
PapaStein
Low and Slow!
Barnett clutches and cables.
There you get.
I just got off the phone with Barnett, and yes I have to agree this is hands down the go to for cables at least. Their cables are more robust and also teflon coated making them easier to pull. They do not have BigDog listed on the website so you will have to call them, but they do have all the specifications on these bikes. 4-5 days for the build because they do not stock them. They are built as they are ordered. And the price was way less than I expected.
Gottaflirt
Leaving it all behind
I appreciate that information. Do they have a website that I can order from. I assume they do. Fixin to go check it out now.
Call Barnett Racing (805-642-9435) direct. Have your measurements ready for their sales department. They are knowledgeable and happy help. Great company to work with especialy if you want to change the length of the cable or jacket. 5 Stars1
Gottaflirt
Had the nut attaching the clutch basket to the transmission input shaft come loose on my 2007 K9 with a Baker 6 speed RSD and my bros 2008 Mastiff same transmission set up. . Amazingly no damage. Torque to 80 Ft. LBS with high strength Loc Tight.
Snuffy
This is a very common issue. Should be checked periodically. These bikes do require more maintenance than most. If you just want to occasionally ride and don’t want the maintenance then buy a honda.
PapaStein
Low and Slow!
Hey y’all,
I ain’t had much time to be on here, trying to get caught up on things I’ve been neglecting before it gets cold. Just wanted to update and reiterate, Barnette is absolutely hands down the way to go for a clutch cable, and probably any other cable. The cable I received is more robust all around and fit perfectly. With their teflon coated cable the clutch pull is probably 40% lighter which is awesome if you’ve got arthritis. I put it on and adjusted it and immediately I was able to get neutral with no problem, every time. I have rode quite a bit since putting it on, I’d say at least 500 mile, and I’ve not adjusted it since the initial at installation. I’m going to adjust it now just because I feel like it should need to be adjusted but it’s still working fine. I appreciate everyone recommending Barnette. I was initially nervous about the cost but when it was said and done it came out just a few dollars less than where I ordered the first one.. Ride easy friends.
