RADAMS445
RADICAL
That story never and I mean NEVER gets old!!!!!:roll::up:I know a guy the did a valve job because his gas tank rattled!!!![]()
doh..
:roll::roll::roll::roll:
dude, that's wrong; heheh
That story never and I mean NEVER gets old!!!!!:roll::up:![]()
:angry:
I'm still of the belief that if it's trying to turn over and not able then your battery just can't support it.tried and tried to turn over not a good thing I am sure. Any Ideas on what to try now?
What did you clean those contacts with? They need to be as smooth as possible when you're finished or else they can easily arc and get stuck together or just not make a good contact.decided to take the cover off and tried pushing the plunger into the starter it stuck and tried to turn over not a good thing I am sure. Any Ideas on what to try now?
Maybe...At least it was probably warranted with 65,000 miles on the motor!!
Most definitely!!!! :up:Or stems from listening to all the horror stories on here!
Glad to hear your up and running Paul...I got it! the bike is running thanks to all who helped. Eric is the man he helped me through this and all of you who gave me advice it was appreciated. This is embarrassing but thought I would share with the group so if there are any other knuckle draggers out there hopefully this will help them. I have a scorpio alarm with a ignition kill switch installed and after using the volt meter to test the battery 12.6 (good) tested the wire that plugs into the solenoid "nothing" so I decided with help from Eric to run a jumper wire from the + battery to the solenoid and sure enough it started to crank. Now this is what got me started thinking about the alarm and ignition kill switch decided to grab the pager and turn the alarm off and hooked the wire back to the solenoid, fired the bike up on the 1st try When I disconnected the battery to do the starter maintenance it set off the ignition kill switch. Hopefully someone can learn from my "bonehead mistakes" Knowing my luck I will depend on the forum for all the great help. I am a beginner but I hate having anyone else do work that I should be doing! Thanks all for your time and effort.
Paul
whats your voltage?When I push down on the solenoid the bike wants to crank over as soon as I put the cover back on the bike just clicks! It does not seem to be making contact. HELP any suggestions are welcomed
