Clean Diamon cut
easy riders
Hi Friends,
How can I clean the diamond cut on the engine. I see some oxidation, I try everything but still cannot get it clean. it is deep
thx
rasdes
3000 Wet Sandpaper used carefully and only where necessary, then billet polish with a lot of rubbing.
BigDogBro1
Made in the USA
I would think using sandpaper would knock off the facet cut edges of the diamond cut and may cause it to NOT look like diamond cut.
I would just use a polish compound for the heavy oxidation and then a good aluminum polish to finish.
I can't imagine any oxidation being that bad unless the bike had been stored in a damp area or outside in the weather.
easy riders
the outside is clean but to clean the groove inside is the issue, I use power ball but it cannot go deep to clean the oxidation
francoblay1
The Spaniard
In any gun/hunting shop or just Google it and you will find hundreds of pages where to buy it from..
eg. [ame="http://www.amazon.com/Tipon-Deluxe-inch-Cleaning-Rod/dp/B00F3BOIK4"]http://www.amazon.com/Tipon-Deluxe-inch-Cleaning-Rod/dp/B00F3BOIK4[/ame]
FrankBDPS
Any round wire brush will do. I use brass or stainless steel ones. Are you allowed to have firearms in your country?
